  • 26 Vote(s) - 2.58 Average
Strange opening problem
I have a bft Phobos/Thalia L 24v single gate kit using a pair of SEAV 2241 photocells. All works fine except occasionally if I want to open the gate first thing in the morning it won't open, if I stand between the photocells and break the beam it will open as normal but as soon as I move it stops. Later in the day it will sort itself and work as normal.
so essentially you are using your photocells as a means to open your gates am i correct in saying this?
Thanks for your reply. I'm using a keypad and remote to open the gate, the photocells are there to stop the gate closing when there is an obstacle (ie a car) in the way. Most of the time they work fine but occasionally they seem to work in reverse so the gate will only open when the beam is broken.
So, for anyone that has this problem on the future, it was the glare from the morning sun blinding the photocell. Hopefully a guard over the sensor will fix the problem ?
(06-07-2019, 06:53 AM)Baz1981 Wrote: So, for anyone that has this problem on the future, it was the glare from the morning sun blinding the photocell. Hopefully a guard over the sensor will fix the problem ?
The guard should fix the problem.
If the problem still occurs, we recommend trying some move-able photocells that can be moved into different angles to avoid direct sunlight causing a problem.
  Bft gate problem djkokalis 1 1,276 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 952 14-02-2024, 12:18 PM
  BFT opening problem 8 45,416 08-08-2023, 02:14 PM
  BFT SubR not opening/closing sometimes Jimmyboy4 3 2,996 09-01-2023, 10:29 AM
  PHOBOS N Manual Overide Problem Dazrob 3 2,462 06-12-2022, 07:29 PM
Last Post: Dazrob
  BFT Lux 2B FC Motor not opening all the way to stopper jc.34@outlook.com 8 8,532 19-08-2022, 09:30 AM
  bft hydraulic gate problem richh 4 22,347 23-12-2019, 04:36 PM
Question Bft Rigel 5 Gates - Sticking when opening dannys1 3 57,867 23-04-2019, 10:11 AM
  BFT Rigel 4 receiver signal problem drmrking 1 10,291 10-09-2018, 05:34 PM
Last Post: drmrking
  BFT A 40 not opening tojo 0 6,027 06-12-2017, 11:29 PM
Last Post: tojo
