  • 31 Vote(s) - 3.1 Average
I Need Advice on Choosing the Right Automatic Gate System.
Hello there,
I am in the process of upgrading the gate at my home and looking for advice on choosing the right automatic gate system. I have been researching various options but still feel uncertain about the best choice for my property.
I am considering either a sliding or swinging gate; but I am leaning towards a sliding gate due to limited space at the entrance.
My driveway is fairly standard in size, but I want to ensure that the system I choose can handle a heavier gate if I decide to go with something more substantial in the future.
Security is a key concern for me; so I am particularly interested in systems with good locking mechanisms, remote access, and maybe even integration with smart home systems.
I have read some reviews; but I would appreciate hearing from anyone who has experience with specific brands or systems. What do you recommend for a home of this size? Are there any features that are must haves for long term durability and security?
Also; I have gone through this post; https://www.gateguide.co.uk/attachment.php?aid=79 which definitely helped me out a lot.
Thanks in advance for your help and assistance.
You should try the Beninca automated system, as it is a very reliable make which comes with two years of warranty. And if you purchase from https://natim.co.uk/ , we'll add an extra year to the warranty, resulting in 3 years of warranty on the automation system.
Other brands you can consider are Roger Technologies and Fadini automated systems. Moreover, all three of these automation systems might be a bit expensive, but they are worth the pay as they are very good for long term durability and ensure better quality. Selecting stronger motors will ultimately lead to longer product life.
Here's a more detailed explanation w.r.t the selecting the gate design and based on our experience with gate installations in driveways, similar to yours:
Sliding gates are space-saving and come in two varieties: one with wheels on track and the other is a cantilever sliding gate.
For a wheel on track, assuming the size of your entrance is 3 metres, then you need at least a minimum 6.3m space (which includes the 3m driveway entrance and 3.3m space behind your fencing) for the gate to be fully open. You'll also need 6.3m of footing for this gate.
Cantilever gate - you need 8.5 metres space for the gate to be fully open. The sliding gate of this kind needs a 2.5m footing.
Another sliding gate type is the Sliding telescopic gate.
It's similar to a wheel on a track, but lets you save space since it's a 3-metre gate and only needs 2 more metres for full opening.
In terms of sliding gate security, we can install an extra limiter to prevent lifting, whether the gate is open or closed.
A swing gate might be a good option if you find the space and footing requirements for the sliding gate too much.
And again for swing gates, we still recommend Beninca automation systems.
Security - we can use electric drop bold which will be in operation at the same time as the gate. In addition mag lock for better security.
All hinges - vandal protection.
Another alternative to swing gates is the Bi-folding gate; both sides are bi-fold gates. Similar solution as swing gate, however, you will only need max 1m of the driveway for the gate to open.
Below are images for your understanding:
1.  Bi-folding gate with Beninca automation system - Closed
[Image: WhatsApp-Image-2022-04-07-at-22.04.00-3.jpeg]
2. Bi-folding gate with Beninca automation system - Opened
[Image: WhatsApp-Image-2022-04-07-at-22.04.00-6.jpeg]
And if you still need more information, please feel free to follow the links in my signature. Alternatively, you can also reach out to the folks at EasyGates.
A gate consultant working with Natim Services.
Here's some services we offer:
Repairs:
Electric gate repair
Gate repairs
Fence and railing repair
Installations:
Metal Gates
Metal Side Gate
Fences and railings
(02-12-2024, 10:40 AM)Try mytoolsshop.co.uk they do good quality sliding gate kit and also automated system. Wrote: Hello,
(26-11-2024, 07:56 AM)lizaclarraa Wrote: Hello there,
Thank you for your message.
If you need help selecting a suitable gate automation kit, we can definitely help with that.
Could you please provide us with the below information on email technical@easygates.co.uk where we can do a formal quotation that is tailored to your needs and your exact application.
1. Length per Leaf: Please provide the measurement of each gate leaf individually.
2. Estimation of Weight per Leaf: Kindly provide an estimation of the weight for each gate leaf. This information is crucial for selecting the appropriate motor and accessories.
3. Number of Cycles per Day: Please let us know how many times the gate is expected to open and close in a typical day. This helps us determine the duty cycle requirements for the automation system.
4. Open Boarded or Closed Boarded: Specify whether your gate is open boarded or closed boarded. This information affects the type of automation system suitable for your gate design.
5. Maximum A Measurement: Measure and provide the maximum distance from the hinge point to the furthest point of the post you can mount a bracket to.
6. C Measurement: Measure and provide the distance from the hinge-pin to the edge of the post, please note If your gate is rear-hinged this will look like the diagram on the right.
7. Images of the Gates: Please provide us with some images of the gates, this will allow us to see if there may be any considerations to keep in mind that may hinder the automation.
8. Windy/Exposed Location: Are the gates situated in an exposed/windy location?
To assist you further, please refer to the attached diagram for a visual representation of the A and C measurements.
  Came gate opener remotes Alexlambrook76 1 2,366 19-05-2026, 02:07 PM
  one gate partially opening - board failure ? kathome 1 1,889 19-05-2026, 02:06 PM
  One side opens erratically - both gate stops sheared?? bomitie 0 1,843 18-04-2026, 03:18 PM
  gsm/smart/proximity advice dave363474 1 1,706 06-03-2026, 03:35 PM
  Gate transmitters intermittently working Nice MC824H solihul 1 3,644 28-01-2026, 10:17 AM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 4,568 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 81,485 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 9,658 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 4,596 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 7,960 09-05-2025, 12:36 PM
