  • 303 Vote(s) - 2.9 Average
I've posted this in BFT as well but there is also a general question.
Thanks in advance
.pdf   SUb.pdf (Size: 57.98 KB / Downloads: 1,065)
Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
The legnth of the leaf is very important. For the size of each leaf being 2.5m you would require the SUB ER motors. The boxes you have already installed would be compatible. The SUB ER motors will be quite alot slower than the SUB R motors. They are also non-locking so security will be an issue as you can force the gates open.
With these non-locking motors, the seals will not break and should last a long time with regular service.
We can get these motors ordered in for you if you require them
If you need any more details please call us on 0845 054 50 70 and ask for Technical.
(13-04-2010, 06:44 PM)jgpp Wrote: Thanks for the reply, I've just removed the lid and the pump is marked Sub R. Now looking at the spec sheet for Subs it says these are suitable for up tp 1.50m, our gate leafs are 2.5, though I don't think they will weigh any where near 800kg. Is this critical ?
Thanks once again
  Gate mobile phone ‘relay’ jam_rs 1 96 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 113 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,587 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Replacement remote Chindley 1 2,030 06-12-2023, 03:00 PM
  Replacement Above Ground Mechanism Advice Amadeus 0 617 29-07-2023, 12:47 PM
Last Post: Amadeus
  Holding the Gate Open mgb 1 4,042 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,300 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,858 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,737 25-05-2023, 03:55 PM
Last Post: Kaala1
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,559 04-05-2023, 04:02 PM
