  • 311 Vote(s) - 2.86 Average
Proteco gate code remotes
Hi I have a proteco advantage unit opening double gates, it stopped working yesterday but I got it going again by cleaning the photo cells, unfortunately all the remote key fob codes seem to have been lost. I have tried to reprogram them but I can't get the unit to accept them, I am following the instructions to the letter, the red 'full stop dot' that should appear when I press button C and the remote button won't light up and the code is not accepted. The gate works fine on the key switch, I have tried 4 different fobs and they are all the same. Help!
In order to best advise, need clarification on the key fob:
1) When the button is pressed and held on the keyfob, does the light on the keyfobs turn red or green?
2) When the button is pressed and held on the keyfob does the red dotr appear on the screen?
If the remote is showing a red light, this indicates Low battery and / or signal weakness therefore the receiver has a much less chance of picking up the signal. This is rectified by re-modulating the keyfob code (rolling code) until we see a green light on the keyfob - and/or changing the battery. However, if the key fob is showing green light and you still see no dot on the screen, this indicates radio card failure.
Kind Regards
Gate Motors
01202 717191
  TC fault code on Q60ar control board Skydive1710 3 3,592 20-11-2023, 03:12 PM
Last Post: NormanY
  Proteco Advantage (Q60A) Error Code "03" CLAUDIOTX 3 18,034 26-09-2023, 05:32 AM
Last Post: max666
  Holding the Gate Open mgb 1 3,855 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,132 03-07-2023, 08:54 AM
Exclamation Proteco Q60A stopped working xCO 0 982 19-06-2023, 01:03 PM
Last Post: xCO
  BFT gate and Hikvision wiring help Gowrie 0 3,704 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,617 25-05-2023, 03:55 PM
Last Post: Kaala1
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 20 17,040 15-05-2023, 11:25 AM
Last Post: Nemen3242
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,383 04-05-2023, 04:02 PM
  Q80A Fault Code kevcl15@yahoo.co.uk 1 2,048 03-02-2023, 12:00 PM
