  • 17 Vote(s) - 3.24 Average
Came za3 one gate not working from fob
Hi all,
We have a front and rear gate at our current rental, the rear gate will open and close from the fob but the front gate will not, it will open from the keypad and from the switch inside the house. Any suggestions on a fix for this would be appreciated
(14-01-2026, 01:12 PM)darrenp363 Wrote: Hi all,
Hi Darren,
This is a strange fault from which you have described. As the keypad and switch will work the front gate we know that there isn't an issue with the gate automation as such. This either leads me to believe there is an issue with the radio remote receiver at this gate, or a problem with the button you are using on your remote for this gate.
Does this issue still occur on multiple remotes, or is it just the one remote which has this problem? I would try pairing a different button on this remote to the front gate to see whether it is the button which is causing the issue.
Many Thanks,
Aiden.
  CAME F7000 Gate Openers Issue Jackolantern 7 18,599 03-11-2025, 08:46 AM
Last Post: Jackolantern
  CAME sliding gate drops codes after power outage Catch 1 11,762 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 19,216 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 26,378 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 16,074 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 36,726 20-12-2012, 02:40 PM
Last Post: TobagoGate
  Came A3000 stopped working Evo 5 35,030 05-03-2011, 03:00 PM
Last Post: Evo
