  • 22 Vote(s) - 2.86 Average
Nice RB600 - Automatic close fail and opening issues
Hello,
Hope everyone is doing fine.
I have a Robus RB600 gate and have 2 issues I'd need help with.
1. The automatic close is enabled, however it only works if nothing passes through the gate during that time. If a car or a person breaks the the photo beam during this time, it will not auto close anymore...
2. During the opening, if a car passes before the gate is fully opened, the door halts at that point, and will not continue to open as it should. tried various settings w/o any success.
I would really appreciate any help with this.
Many thanks in advance!
Bump up! 38 views and no answer....Would really appreciate any help with these issues, Thanks!
Did you solve this issue? currently facing the same problem
(09-12-2024, 09:17 AM)nicenotnice Wrote: Did you solve this issue? currently facing the same problem
Unfortunately not yet. But I realized this place is a place for questions NOT answers…
The board is receiving a second command. If you could call through to the number below, we can assist you on this.
01384569942
Easygates Ltd
Have you tried to connect to SBS and programming in apartment block? tried and it works for us.
(09-12-2024, 12:45 PM)Michael Wrote: Hi,
01384569942
Easygates Ltd
Thanks, appreciate the offer. I was hoping to get the info (which seems to be trivial to an experienced gate installer) here, w/o paying for it, that is why I posted the screenshots of my configuration...
Best!
  Nice gates don’t close after the ambient temp is high Howard 1 421 08-07-2025, 10:12 AM
Last Post: old guy
  Nice Control unit passcode removal Andruelectricgates 1 743 17-06-2025, 11:25 AM
Last Post: HarrisonN
  Nice LFAB occasionally failing open DaveHG 0 858 27-05-2025, 09:23 AM
Last Post: DaveHG
  MC800 NOT OPENING FOR WHITELISTED PLATES AFTER FACTORY RESET Wenzo 4 1,307 27-05-2025, 09:09 AM
  NICE gates open slightly then stuck Overthefence 2 1,284 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 1,513 09-05-2025, 01:07 PM
  Mag-lock not activating after close benkay 4 6,530 13-03-2025, 04:19 PM
Last Post: ldkerlukeHome
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,241 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 1,988 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice MC824H Set Up issue dmrgate 2 4,437 10-12-2024, 10:31 AM
Last Post: dmrgate
