  • 16 Vote(s) - 3.19 Average
Nice Walky on 24v
I was hoping to use the Walky to open a small swinging gate and already have 24v to the area. It looks like the Walky has the option to run on battery back-up (14.4v) or via the Solemyo solar (24v I believe) either of which can be plugged into the optional power input on the control board.
Just wanted to confirm that should work with 24vdc or if anyone has something similar?
With the Walky system, you would need 230 VAC at the control panel, this will be stepped down to 24v to power the motors/accessories etc.
Many Thanks.
  Nice gates don’t close after the ambient temp is high Howard 1 472 08-07-2025, 10:12 AM
Last Post: old guy
  Nice Control unit passcode removal Andruelectricgates 1 797 17-06-2025, 11:25 AM
Last Post: HarrisonN
  Nice LFAB occasionally failing open DaveHG 0 887 27-05-2025, 09:23 AM
Last Post: DaveHG
  NICE gates open slightly then stuck Overthefence 2 1,329 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 1,551 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 2,271 16-02-2025, 05:16 PM
Last Post: gatekeeper
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 2,001 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 6,313 10-12-2024, 11:29 AM
  Nice MC824H Set Up issue dmrgate 2 4,483 10-12-2024, 10:31 AM
Last Post: dmrgate
  Nice O-Box Software Andruelectricgates 1 3,090 09-12-2024, 12:52 PM
