  • 21 Vote(s) - 2.52 Average
BFT Rigel 5 with with two electromechanical operators Swinging gate inherited from the previous home owner, left no clue of what it is  or what so ever.
are they still working?
They don't have limit switches, somehow increase the motor torque and slowdown time/show down torque works. I figured that increased Motor torque would amplify the effect of slow down effect, given the slow down torque set to maximum of 99. One thing I am not sure is the braking effect and open/close impulse. Manufacturer, for some reason, not willing to explain more about these effect to me.
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,261 04-05-2024, 12:47 PM
  Gate wont close issue MR_ROBOT 3 9,951 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,425 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 1,100 14-02-2024, 12:18 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,537 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 937 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,286 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,340 02-10-2023, 09:08 AM
  Rigel 6 conections Muttlymoo1979 0 1,396 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Set remote to “only open” gate mark123499 4 3,984 30-05-2023, 01:57 PM
Last Post: mark123499
