  • 257 Vote(s) - 2.61 Average
Circuit board disabled CB124 - 7 flashes
The DNG is flashing 7 times indicating that the photocells have an issue and preventing the gates from working even though no photocells are fitted! The system has been working for 2 years with no problem, last weekend I tried to program in a 3rd remote, this seemed to stopped the other two remotes from working and the DNG started flashing 7 times.
I have tried resetting to factory settings by pressing P3 for ten seconds. I have tried reprogramming the other remotes. Turning the power on and off but nothing is working.
I can make the gates open and close by pressing 1,2,3 simultaneously and then P1 or P2 but once the yellow learn lights goes out after 20 seconds the DGN red lights starts flashing again 7 times.
Can anyone offer any advice? I have read in another thread that if no ohotocells are fitted you need to add a link into Photo1 and the Com, is this correct? If so, why has the system worked for 2 years!
I am tearing my hair out as nothing seems to be fixing this!
(11-01-2015, 05:59 PM)Tussun Wrote: Hi there I have the same Issue I accidentally put it into this mode when trying to add a new remote and cant get it out of this mode, i have 8 flashes which refers you back to the 7 answer, i do have photo cells however but all was working well before i put it in programming mode.
Did you manage to solve this and if so how.
Chris
I have the same issue - did you manage to get is solved - i am about to order a new board which seems a bit of an extreme solution!
Cheers
Chris
(11-01-2015, 05:59 PM)Tussun Wrote: The DNG is flashing 7 times indicating that the photocells have an issue and preventing the gates from working even though no photocells are fitted! The system has been working for 2 years with no problem, last weekend I tried to program in a 3rd remote, this seemed to stopped the other two remotes from working and the DNG started flashing 7 times.
Long time ago but did you ever solve the problem ?have similar problem with liftmaster SCS200 / Chamberlain TPD10. Just blinks 7 times but not photocells are connected even. Pressing P2 and then P3 to remove auto close doesn't help.
If you are not using photocells have you got dipswitch 5 off and have you linked out all the photocell terminals?
I Did contact Chamberlain in the end. Aand apparently I was just dumb, for some reason my new PCBs blinks 7 times before it is programmed, so it was no fault.
Glad to hear the issue has been resolved, if you have any further queries regarding this operator feel free to contact our technical team at technical@easygtaes.co.uk
  Fried control board nickfr 3 5,988 22-03-2024, 12:53 PM
  BFT key pad not communication with digital board niall.paul@yahoo.co.uk 1 4,049 14-02-2024, 12:21 PM
  Faac 452 pcb board benner91 2 7,102 09-02-2024, 06:13 PM
  TC fault code on Q60ar control board Skydive1710 3 10,540 20-11-2023, 03:12 PM
Last Post: NormanY
  Replacement Q60A board? ndyhzlwd 1 6,068 10-02-2023, 03:19 PM
  Nice Robus RB100 - Control Board Buttons Not Working sl991 5 12,690 02-12-2022, 02:51 PM
  Beninca bob motor wiring to board Ranch2 6 14,116 18-11-2022, 09:59 AM
  CAM ZA3 Single control board Rookie 1 11,344 13-04-2022, 11:37 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 8,849 02-05-2021, 09:00 PM
Last Post: soother
  LIGHT FLASHES will not stop Pablo 1 7,052 31-01-2021, 04:20 PM
Last Post: Pablo
