  • 2 Vote(s) - 1 Average
Bft gate one door stopping
Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Many thanks in advance.
(12-04-2022, 07:52 PM)Matty c Wrote: Hello.  I have a pair of gates bft. Motors under the  ground.  One of my gates seem to stop mid way.  The other one is fine.if I gently push it.  It will carry on to close or open.  I've checked the motor and it seems dry and not water damaged.  Been in operation for 12 years now.   Am I right in saying it's the motor needs replacing ?  Just got worn out.
Hi Matty,
Thanks for the email,
There are two likely explanations for your issue, one could be if this is a 230v system it could be that the capacitor is on its way out and would likely need replacing, a way of testing this would be to switch over the capacitor and test the motor to see if the fault persists, another plausible issue could be that the motor force on this leaf is not set high enough.
Kind Regards
Hi Matty,
Kind Regards
[quote pid="16553" dateline="1649846569"]
Thanks Joe.   It is a 240 system.    I havnt changed the motor force setting and has been the same for  years and has work faultlessly.   I reckon it must be the capacitor.   Many thanks for your help. Matty
[/quote]
Hi Matty,
Kind Regards
[/quote]
Hi Matty,
Thanks for your response, glad to hear we could be of assistance.
Kind regards,
  Gate mobile phone ‘relay’ jam_rs 1 55 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 80 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,498 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Holding the Gate Open mgb 1 4,022 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,283 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,841 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,736 25-05-2023, 03:55 PM
Last Post: Kaala1
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,539 04-05-2023, 04:02 PM
  Electric gate help PLEASE Be8st 5 6,283 18-10-2022, 09:26 AM
  2014 model BFt rolling gate automation lauriston 1 6,328 07-03-2022, 11:11 AM
