  • 4 Vote(s) - 2 Average
Remote only working close up
Hi guys and thanks for having me on board.
My gate is a single 3.4m wide opener controlled by a BFT Sub Hydraulic unit operated by a controller identical to the one shown in this video:
I had to add two new Mitto remotes exactly as in the video. It turns out there have been a good few remotes added over the years. Anyway, the problem now is that if you are more than five or six metres away, the remote will not work the gate. You get closer and it works perfectly. I have checked carefully the remote antenna cables and they are securely attached. That is my electronics expertise exhausted.
This is really becoming an issue now as you have to open the car window and wave the remote about in order to get it to work. Nothing has changed and this applies to the new and original remotes alike. Previously you could be a good way off and it would work.
  Gate wont close issue MR_ROBOT 3 9,746 11-04-2024, 08:08 AM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,395 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 831 19-01-2024, 09:54 AM
  Set remote to “only open” gate mark123499 4 3,858 30-05-2023, 01:57 PM
Last Post: mark123499
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,800 10-10-2022, 01:10 PM
  RCD trip on close LUX 2B DP86 3 6,696 14-04-2022, 08:55 AM
  BFT controlled gates open but don't close MikeJep 5 19,837 04-01-2022, 09:58 AM
  Gate won't close on manual or auto Baz1981 0 5,934 23-06-2020, 05:27 PM
Last Post: Baz1981
  BFT keypad code not working VDPJ 0 3,547 25-05-2020, 03:28 PM
Last Post: VDPJ
  BFT Gate won't open or close Steveturbocal 0 8,619 17-11-2019, 11:10 AM
Last Post: Steveturbocal
