  • 195 Vote(s) - 2.58 Average
Installation Problem - BFT Deimos BT + GSC D MA
Just set up all parts for installing on my rack sliding gate on a "test bench" in the garage, before properly installing (lamp, IR, aerial)
Everything works as it should except .......
When I press button on my gate transmitter MITTO2, and the gate OPENS, the gate does not automatically close later, but when I press button to close gate, it closes, then on its own OPENS after about 10 seconds. So something is working the wrong way around.
Do I have to swop around wires, or programm, or, or, or ....?
I attach a diagram of the present wiring on to the board in the motor.
Thanks for your help.
Bob
May be motor wires wrong way around.
MWJGATES
www.mwjgates.co.uk
info@mwjgates.co.uk
01327301796
(27-12-2015, 09:01 PM)MWJONES Wrote: May be motor wires wrong way around.
Can I just switch them around to try this, without any possible damage ensuing?
Yes, there is no + or - with motors.
MWJGATES
www.mwjgates.co.uk
info@mwjgates.co.uk
01327301796
(27-12-2015, 09:40 PM)MWJONES Wrote: Yes, there is no + or - with motors.
Just tried it and swopped the cables 1 and 2 in the diagram........ it works, now it only automatically CLOSES the gate, as it should, but!!!!! Now the Limiting switch only works the wrong way around!
....../. perhaps I should try swopping the wires on the limiting switch?????
Thanks, you gave me the courage! I just swopped wires 1<->2 and 6<->7, and everything is 100%!! Still don't understand why swopping AC wires can make any difference, but it obviously does. Thanks again.
  Question BFT Deimos A400 Makaroni 0 133 15-05-2024, 08:05 AM
Last Post: Makaroni
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 6,979 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 1,176 05-03-2024, 04:17 PM
  Bft gate problem djkokalis 1 1,601 14-02-2024, 12:39 PM
  BFT opening problem 8 45,922 08-08-2023, 02:14 PM
  PHOBOS N Manual Overide Problem Dazrob 3 2,592 06-12-2022, 07:29 PM
Last Post: Dazrob
  bft hydraulic gate problem richh 4 22,485 23-12-2019, 04:36 PM
  Strange opening problem Baz1981 4 82,056 15-07-2019, 08:39 AM
  BFT Deimos Ultra remote problems shaggy 1 11,439 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 6,813 30-04-2019, 09:32 AM
Last Post: ok.dude
