  • 263 Vote(s) - 2.69 Average
nice electric gates
hi guys,
I have a problem with my nice a6 electric gates.have read manual have not got 24 volts on terminals 21 and 22.think transformer is working .please help
cheers andy
These contacts should definitely have 24V AC coming out of them. If you are not reading this low voltage output, I should check your low amp fuse on the board and also check for any burnt out tracks on the rear of the panel. Any water damage to the panel will be recognisable by white residue. If you link out the photocell contacts do the gates start functioning? If its just the accessory power output which has failed, rather than buying a new panel, you could use a separate PSU to power your photocells and other accessories.
(22-03-2014, 11:24 AM)rose.andy Wrote: hi guys,
cheers andy
  Rigel 5 , gates won't open Nameloc 2 3,767 23-04-2024, 08:35 AM
  Gates tripped Phil.c 2 207 22-04-2024, 11:27 AM
  Came ZA3 gates stuck open Ivorwindybottom 0 375 18-02-2024, 06:29 PM
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,609 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 8,964 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,846 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,569 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,651 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Nice Moonbus Photocells - Faulty? ddaddy 2 2,093 11-07-2023, 01:33 PM
  Nice HS400 Andruelectricgates 0 940 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
