hi guys,
I have a problem with my nice a6 electric gates.have read manual have not got 24 volts on terminals 21 and 22.think transformer is working .please help
cheers andy
These contacts should definitely have 24V AC coming out of them. If you are not reading this low voltage output, I should check your low amp fuse on the board and also check for any burnt out tracks on the rear of the panel. Any water damage to the panel will be recognisable by white residue. If you link out the photocell contacts do the gates start functioning? If its just the accessory power output which has failed, rather than buying a new panel, you could use a separate PSU to power your photocells and other accessories.
(22-03-2014, 11:24 AM)rose.andy Wrote: [ -> ]hi guys,
cheers andy
