  • 12 Vote(s) - 3.25 Average
#21
Hello
Thank you!
Thank you!
Thank you!
Thank you!
Thank you!
Thank you!
(10-05-2024, 04:35 PM)Nemen3242 Wrote: Try this. This should also help https://www.shelly.com/en-gb/products/pr...lly-plus-1
I don't know unfortunately
  Program a 3rd party remote to Nice Robus N600 P100D 4 225 13-05-2024, 03:36 PM
  Gate mobile phone ‘relay’ jam_rs 1 162 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 183 13-05-2024, 02:32 PM
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 2,009 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,772 24-08-2023, 01:34 PM
  Holding the Gate Open mgb 1 4,076 11-07-2023, 01:35 PM
  Nice Moonbus Photocells - Faulty? ddaddy 2 2,224 11-07-2023, 01:33 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,332 03-07-2023, 08:54 AM
  Nice HS400 Andruelectricgates 0 979 09-06-2023, 09:28 PM
Last Post: Andruelectricgates
  BFT gate and Hikvision wiring help Gowrie 0 3,888 26-05-2023, 02:05 AM
Last Post: Gowrie
