  • 282 Vote(s) - 2.95 Average
GATE OPENING INDICATOR
Hi All,
Does anyone know of a device,that sounds a buzzer/light at the house when gate is opening?
[/font]P.S.I
Not sure what are you after Evo? Most controllers have some additional outputs activated when gate is in motion or motion+open. Otherwise you can use flashing light output to trigger whatever you need.
www.webseb.co.uk
Thanks for replying,im sorry i did'nt clearly explain what is wanted, the gate is on a farm ,at the main drive entrance ,the farm house is approx 130/150 yards from gate so i dont want to be running a cable from panel to house ,so a wireless device is required for the job operating as following. When gate is opening, a sounder/strobe will sound at the house ,i have thought about a wireless door bell ,connected the bell push, in parallel to the "open/com" terminals in gate panel. So when gate gets open command it also triggers bell push which activates door bell at the house , if ther is a unit that will operate at that distance,?? Thanks Again.......Evo.
[/font]P.S.I
I see! I would go with good range radio Tx and Rx. For Rx you'd have to use aerial on this range. If there is output from the panel then you can connect it directly. If not, then I'd connect relay to trigger Tx. In house I'd use receiver, PSU and whatever is required (strobe or sounder).
In regards to range I'd speak to suppliers but in straight line it shouldn't be a problem for good quality set. Receiver and transmitter IMHO is what you need not a door bell but I guess bell will do the job as well
www.webseb.co.uk
  Gate mobile phone ‘relay’ jam_rs 1 150 13-05-2024, 02:37 PM
  Nice MC824H gate stuck open Markp80 1 170 13-05-2024, 02:32 PM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 28 17,791 10-05-2024, 08:27 PM
Last Post: Nemen3242
  Gates Opening After Closing tht7 2 9,795 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Holding the Gate Open mgb 1 4,064 11-07-2023, 01:35 PM
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 4,324 03-07-2023, 08:54 AM
  BFT gate and Hikvision wiring help Gowrie 0 3,881 26-05-2023, 02:05 AM
Last Post: Gowrie
  Control Unit CLB202 Gate leaf learning issue Kaala1 0 3,741 25-05-2023, 03:55 PM
Last Post: Kaala1
  gate stop broke - any spares=liftmaster 300 bomitie 2 4,581 04-05-2023, 04:02 PM
  Electric gate help PLEASE Be8st 5 6,293 18-10-2022, 09:26 AM
