  • 21 Vote(s) - 2.52 Average
BFT Rigel 5 with with two electromechanical operators Swinging gate inherited from the previous home owner, left no clue of what it is  or what so ever.
are they still working?
They don't have limit switches, somehow increase the motor torque and slowdown time/show down torque works. I figured that increased Motor torque would amplify the effect of slow down effect, given the slow down torque set to maximum of 99. One thing I am not sure is the braking effect and open/close impulse. Manufacturer, for some reason, not willing to explain more about these effect to me.
  BFT Sliding Gate randomly opening and closing AdrianMate 2 1,301 17-05-2024, 10:30 AM
Last Post: Adamit
  BFT Rigel 5 issue Adamit 0 74 17-05-2024, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,447 04-05-2024, 12:47 PM
  Gate wont close issue MR_ROBOT 3 10,142 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,602 14-02-2024, 12:39 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,706 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 1,072 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,423 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,525 02-10-2023, 09:08 AM
  Rigel 6 conections Muttlymoo1979 0 1,515 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
