28-06-2009, 11:58 AM
I have two separate Chamberlin Motor lift 2000 garage door openers fitted, one has never been a problem but the second has always been temperamental since it was installed.
I recently tried to use it again and experienced problem, i.e. it would not open. I was advised to reprogram the remote from the second motor to identify if it was the remote. I did this and the door opened perfectly, however when I attempted to press the remote to close the door, the door moved approximately 12 inches and then opened again and did this repeatedly. I only managed to close the door by continually pressing the remote to stop the door from closing before it would close a further 12 inches.
I have disenaged the motor chains and the doors runs incredibly smoothly so the rails/runners are not causing the problem.
Can someone please help?
