  • 229 Vote(s) - 2.9 Average
Came 432NA
We have 3 remotes Came TOP-432NA and non are working. My electrician thinks they all need re setting or re programming. Does anyone know how this can be done.
I have previously re programmed one from another but how is this done if all 3 are not working ??
Were they previously working? If so it may be a receiver issue rather than a remote. The only way to re program the remotes into the system is to do the following.
1. Re program a master fob to the gate control panel. (Programming depends on the board)
2. Copy the other two remotes from the master. (Can be found in the video below)
http://manuals.easygates.co.uk/copy-came...ols-video/
Hope this helps.
