21-06-2019, 12:09 PM
I'm trying to get a 940EV to link to an older Chamberlain 700 without success.
I have followed the following instructions using 3 times as the enter to select the red learn button but it won't activate. I have already paired a Chamberlain ML700EVGB to the 940EV no problem so I know the 940EV is working. Can anyone suggest another way of getting them to pair?
Set Keyless PIN: Program a Keypad PIN Using Your Garage Door Opener:
- Be sure to clear the garage door area of any obstructions.
- Locate the LEARN button on the garage door opener. See How To Find The LEARN Button.
- Press and hold the " * " and " # " buttons on the keypad until the lights on the keypad stop blinking.
- Enter a 4-digit personal identification number (PIN) of your choice, then press the " # " button.
- Press and release the ENTER button on the keypad the number of times that corresponds with your garage door opener type:
Number of Presses
Garage Door Opener Type
1
315 and 390 MHz Security+ 2.0 (Yellow LEARN Button)
2
315 MHz Security+ (Purple LEARN Button)
3
390 MHz Security+ (Red/Orange LEARN Button)
4
390 MHz Billion Code (Green LEARN Button)
- Press and release the " 0 " button.
- Press and release the LEARN button on the garage door opener. The LEARN LED will light. Within 30 seconds.
- Enter your 4-digit PIN, then press and release the ENTER button until the garage door opener lights flash or two clicks are heard. The PIN programming is complete.
- To test, enter your PIN, then press the ENTER button. The garage door opener will activate.
