Hi freinds .. am new here .. My Robus 600 holds open .. it does'nt close after the pause I set for 5 seconds .. and there are an 8 flashes in the bluebus LED though I don't use it .. I use only normal photocells connected to OPEN slot .. Anyone knows how to fix this??!!!!
Hi Ali,
8 flashes from the bluebus indicates A command that does not permit other commands to be
performed is already present.
Check the type of command that is always present; for example, it could be a
command from a timer on the “open” input.
Do you have anything else connected to the board that could be causing this?
Mike
