Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
(19-06-2020, 11:02 PM)Harrisbhreac Wrote: [ -> ]Hi all hoping someone would be able to help. My friend got decided to make his gates electric so got somebody to come and do it for him. The guy that started the job left my mate in the lurch and is avoiding his calls. He asked if I’d be able to do them as I’m an electrician, I told him I’ve never had anything to do with gates but agreed to help. I’ve got the 455d circuit board controlling 2 swing gates, with remote to open them. When pairing the remote was done we then went onto learning the gates which all went ok but when that was finished nothing happens with the gates when pressing the remote! Was wondering if anyone could help as contacted facc technical and had no luck from them. Thanks in advance
Hi, I had a similar problem (still have an issue), if you use a jumper lead between pins 11 and 14 does the gate operate? I also have jumper leads between pin 19 and 12 & 13 (see fig 7 in the installation manual). My issue now is that its not following the TL Complete sequence that I programmed (TL programme works perfectly).
Hope this helps
