Full Version: Audible alarm required
Hello
Can anybody recommend a suitable component/set up to run an audible alarm off an electric gate when the gate is opening? We have an automatic gate about 100 Mtrs from the house and I would like an alarm to bleep inside the house when the gate opens outside certain hours. We are a large equestrian centre so have a lot of people coming and going, so we only have push button access. But late at night I would like to know when someone has come into the property.
I’ve thought I could replace the warning lamp output with a buzzer and lead a hard wire from that up to the house. But not sure what type of buzzer would work or if there is an alternative solution. Any suggestions gratefully received.
I have a king gates system.
You would need some sort of sounder i believe wired into your panel from your house.
you would need a 12-24v Low wattage beacon with it wired into your switch you would need to manually operate this every night.
Once the switch has been manually operated you would then have a functioning sound system.
