  • 73 Vote(s) - 2.81 Average
BFT Rigel 4 receiver signal problem
Hi, I am hoping someone can point me in the right direction. I have a Rigel 4 with RE01 receiver. Worked fine for 15 years and now suddenly key fob will only work if I go within 1m of control box. So far I have tried;
1) Change key fob battery
2) Try 2nd fob
3) Change aerial (seemed the most likely source of the problem)
Still same problem - neither better nor worse.
I am reasonably knowledgeable about electronics - but not about these control units.
Where should I look next?
Receiver board? Can you even still get these REO1 boards?
The whole control / receiver board looks in great condition.
Any suggestions welcomed.
Many thanks,
Mike
Ok quick update - as someone else may have this issue -
before replacing plug-in receiver with new generation (and transmitters) at some expense - I decided to try and see if it was just the plug in board connection that had tarnished over time (16 years old). Well removing and reseating the receiver board did indeed fix the problem. Now which joint got remade in the process is anyone's guess - it could have just been a solder joint that got remade. But its all working, transmitter range back to 30m rather than 1m ! Hope that helps someone.
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,337 04-05-2024, 12:47 PM
Last Post: Alee
  Bft gate problem djkokalis 1 1,498 14-02-2024, 12:39 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,338 04-01-2024, 10:21 AM
  BFT opening problem 8 45,746 08-08-2023, 02:14 PM
  Rigel 6 conections Muttlymoo1979 0 1,448 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,846 05-01-2023, 11:53 AM
  PHOBOS N Manual Overide Problem Dazrob 3 2,538 06-12-2022, 07:29 PM
Last Post: Dazrob
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 4,996 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,393 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 9,027 30-03-2021, 07:57 AM
Last Post: Matt Hey
