  • 297 Vote(s) - 2.79 Average
Gate closing but not opening
Question
Hi, I have a BFT Sliding Automatic gate with Deimos motor using Mitto fobs for remote opening / closing. Installed about 5 years ago. Gate is opening but not closing. It moves about 6 inches back to close and then gets stuck ? What should I check or look for please ? Simple instructions please I'm a woman ! ALL advice very Smile welcome.
Kindest Regards,
Dave
Dave Blake
Thank you Dave. Will try and let you know.
(12-06-2014, 09:26 AM)Blakey111 Wrote: Hi,
Kindest Regards,
Dave
Hi Dave
Problem solved. It was the spring that was disengaging from the bent "arm"....thank you for your help...Smile
Kindest Regards,
Dave
  Gate wont close issue MR_ROBOT 3 9,758 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,297 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 981 14-02-2024, 12:18 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,184 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,221 02-10-2023, 09:08 AM
  BFT opening problem 8 45,458 08-08-2023, 02:14 PM
  Set remote to “only open” gate mark123499 4 3,870 30-05-2023, 01:57 PM
Last Post: mark123499
Exclamation BfT Sub R - No Closing pressure 1 Leaf Bushpig 2 3,221 23-05-2023, 03:48 AM
Last Post: Bushpig
  BFT SubR not opening/closing sometimes Jimmyboy4 3 3,013 09-01-2023, 10:29 AM
  Gates not fully closing stefen1978@hotmail.co.uk 2 2,765 10-10-2022, 10:07 AM
