  • 271 Vote(s) - 2.85 Average
Gate don't open/close
I've got a reigel 5 bft with under Tarmac openers. It won't open or close. On the panel it says 'phot'. The inner photocells click. Bit the outside ones have got two leds. One that goes off when the beam is covered and another I think is the power led that normally stays on 24/7. That led is not on. But the top one is. The one that goes on and off if the beam is broken. I think I need to replace the outside pair of beams. Any thoughts?
It certainly sounds like the set between the pillars are playing up. I would check the lens covers and make sure there are no bugs or dust blocking the infra red beam which might affect the control panels function. If you do need to replace the cells, I have posted a link to what you will need to order on our website.
Kindest Regards,
Dave
http://easygates.co.uk/product_info.asp?ProductID=261
(04-07-2014, 05:28 PM)Mattycox Wrote: I've got a reigel 5 bft with under Tarmac openers. It won't open or close. On the panel it says 'phot'. The inner photocells click. Bit the outside ones have got two leds. One that goes off when the beam is covered and another I think is the power led that normally stays on 24/7. That led is not on. But the top one is. The one that goes on and off if the beam is broken. I think I need to replace the outside pair of beams. Any thoughts?
Dave Blake
  Gate wont close issue MR_ROBOT 3 9,777 11-04-2024, 08:08 AM
  Bft gate problem djkokalis 1 1,313 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 994 14-02-2024, 12:18 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,421 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 850 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,196 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 2,234 02-10-2023, 09:08 AM
  BFT LUX2B Intermittent failure to open brookkr 4 8,085 07-09-2023, 08:32 AM
  BFT Thalia ‘Hold Open’ hehasmoments 5 4,344 24-08-2023, 01:38 PM
  Set remote to “only open” gate mark123499 4 3,888 30-05-2023, 01:57 PM
Last Post: mark123499
