  • 214 Vote(s) - 2.98 Average
open command
As you can see by my question I am new to gate automation.
I hame a mhouse WG2 kit and want to use a beam on the inside of double gates to open automaticly to allow vehicles out. Do I use the ECS bus or the open connection point and if the open connection point which of the the pins
Thanks for any help
Geoffpb
Hi Geoff you will need to use relay photocells, what kind are you using at the moment?
(16-03-2014, 10:48 PM)geoffpb Wrote: Hi,
Thanks for any help
Geoffpb
  Rigel 5 , gates won't open Nameloc 2 3,864 23-04-2024, 08:35 AM
  Came ZA3 gates stuck open Ivorwindybottom 0 405 18-02-2024, 06:29 PM
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,915 02-10-2023, 09:20 AM
  Holding the Gate Open mgb 1 3,889 11-07-2023, 01:35 PM
  Came gates stuck open. Ring8180 7 17,122 23-02-2023, 01:08 PM
  Nice gate stuck on open akkers 5 12,257 28-06-2021, 09:43 AM
  Genius Brain 17 Control Board - External Open/Close Signal rhennessysummit 1 5,271 02-05-2021, 09:00 PM
Last Post: soother
  Cost of holding gates open Helen 1 5,817 22-04-2020, 10:59 PM
Last Post: Luke Scott
  Gates TRIPPING rcd with internal open/close switch. bomitie 5 83,207 06-12-2019, 11:10 AM
  Help!!!! GSM intercom how do you open gates!? Missfern 2 12,408 11-10-2017, 03:08 PM
Last Post: Access-Control-Ltd
