Proteco Q60A n2 error code
04-05-2012, 05:28 PM
Post: #1
Hi Following a major storm of wind and rain which resulted in a power supply failure my Aster gates have failed to function and go from -- (stand by ) to error code n2 when activated. There was no evidence of water ingress into the control housing and although the earth trip triggered it has reset without problem.
If I reset the parameters to P5 (only one motor) and then successively plug in motor 1 then motor 2,into motor 1 terminals 13,14,15 they both work normally suggesting the motors themselves are OK and the problem lies in the control panel. Both motor fuses are OK. Any advice welcome |
10-05-2012, 10:36 AM
Post: #2
RE: Proteco Q60A n2 error code
Thank you for your posting. Indeed thank you for running a test i would have suggested (fooling board to think there is only one motor attached and running both independently from it) – however, if you swapped both motors round to begin with, would you still see N2? If this was the case, without a doubt I would feel there is an issue developed with terminals 16/17/18 and would look towards: • The condition of the spade contacts on that terminal grouping • The condition of the reverse side of the control board on the off chance something has run across the copper tracking • The level of torque on that terminal grouping output (parameter F2) Kind Regards Gate Motors Technical Support |
11-05-2012, 09:00 AM
(This post was last modified: 11-05-2012 09:05 AM by Horace.)
Post: #3
(10-05-2012 10:36 AM)Proteco_UK Wrote: Hi (11-05-2012 09:00 AM)Horace Wrote:now appears possible that there is an element of damp not visible but hidden between the PCB and underside of components on the Rt. 230V half of the board ,(10-05-2012 10:36 AM)Proteco_UK Wrote: Hi Any more suggestions ? Yours sincerely Horace Thank you for your response I have examined all three possibilities suggested but with no success It |
22-05-2012, 10:51 AM
(This post was last modified: 23-08-2012 11:48 AM by Proteco_UK.)
Post: #4
Without using a volt meter, is hard to determine if those terminals 16/17/18 are at least passing a voltage through them. Your motors have tested fine from your experiements - just leaves the cabling (which you have ruled out from being damp) and the control board physical terminals themselves. |
« Next Oldest | Next Newest »
| Possibly Related Threads... | |||||
| Thread: | Author | Replies: | Views: | Last Post | |
| Proteco Leader rams very slow | drshemmming | 5 | 1,018 |
18-11-2012 09:03 PM Last Post: drshemmming |
| Proteco Q60A n1 Error code | Pariseasy3 | 1 | 1,121 |
23-08-2012 11:38 AM Last Post: Proteco_UK |
| Proteco Q71A | Pike | 2 | 1,151 |
06-08-2012 10:10 AM Last Post: Proteco_UK |
| Proteco Q60S/R - Install probs?? | jadeella1 | 1 | 1,046 |
05-07-2012 01:51 PM Last Post: Proteco_UK |
| Proteco gate code remotes | stroller | 1 | 1,172 |
12-06-2012 09:50 AM Last Post: Proteco_UK |
| Problem with Proteco Sliding Gate Controller | JHONNY33 | 4 | 2,282 |
02-05-2012 10:25 AM Last Post: Proteco_UK |
| Proteco Advantage (Q60A) Error Code "03" | CLAUDIOTX | 2 | 1,527 |
21-03-2012 09:39 AM Last Post: Proteco_UK |
| Proteco Aster's Q60A shows a strange error | exterminator86 | 2 | 2,876 |
25-01-2012 04:33 PM Last Post: exterminator86 |
| Proteco Advantage | sarah | 3 | 3,347 |
21-12-2011 10:12 AM Last Post: Proteco_UK |
| HELP - Proteco Aster | Guest | 2 | 4,628 |
09-08-2011 08:59 AM Last Post: Proteco_UK |
Return to Forum Home
Search
Member List
Calendar
Help
