  • 146 Vote(s) - 3.14 Average
Rigel 5 and sub r
Khi new here  I was wondering if anyone point me in the right direction on how to program check the program of Rigel 5
Problem I’m having is one of the gates works correctly and one gate just move a tiny bit in closed or open  Motor was taken out and as been test at  Electric motor repair shop came back Woking ok
Could  it be the capacitors or
programming of the gate control as the Son try adding new remotes Controls
Hi Steve,
Thank you for your enquiry, i will post below the manual for the Rigel 5 board which will help with programming and error codes. I would advise you to check the motor output terminals on the board if the motor has come back from testing as not faulty. If you are getting the correct voltage once a command to the gates have been given then i would be checking the capacitors, this can be done by swapping the capacitor from the working motor to the motor that isn't working. If the fault moves from motor to motor then we know that this is the problem. Hope this helps and if you need any more assistance don't hesitate to contact us.
http://manuals.easygates.co.uk/PDF/misc/bft-rigel-5.pdf
Kind regards
Tim
  BFT Rigel 5 issue Adamit 0 35 Yesterday, 10:28 AM
Last Post: Adamit
  Just Got A Rigel 5 and need HELP!!!! rapley 2 13,428 04-05-2024, 12:47 PM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 1,412 04-01-2024, 10:21 AM
  Rigel 6 conections Muttlymoo1979 0 1,506 21-07-2023, 08:52 PM
Last Post: Muttlymoo1979
  Er 10 code on RIGEL 6 control unit Eddiew 1 2,924 05-01-2023, 11:53 AM
  BFT Rigel 6 - Buttons suddenly stop working RobE 5 5,086 10-10-2022, 01:10 PM
  Rigel 6 - doors do not stay open Poweroftaxi 1 9,452 13-04-2021, 02:41 PM
  But Rigel 5 and Deane a15 cells Matt Hey 2 9,086 30-03-2021, 07:57 AM
Last Post: Matt Hey
  Bft rigel 6 PHCL tidoh2021 1 11,911 12-03-2021, 07:31 PM
Last Post: russ
Smile Rigel 5 Manual override Stramorebees 0 10,154 20-09-2020, 12:03 PM
Last Post: Stramorebees
