  • 3 Vote(s) - 3.67 Average
flexible connection between gate and ram
We have a single five bar gate suited to our rural location and for 20 years it has been automated to open/close with an above-ground electric ram attached to the mid-point of the top bar of the gate. We need another replacement thanks to a DHL c-Commerce courier who forced it open last week, fracturing the ram close to the motor.
This is a by-the-by except to warn against this dreadful company who do everything they can to dump goods if arriving outside the time slot they promised.
Horizontal fittings are attached to the gate post and when opening from CLOSED to OPEN across the required 90 degrees, this gives the ram operator the required angle and to pull and retract.  However, the hinges of the gate are set so that when opening, the gate rises to cope with the steadily rising drive when entering the property.
This has always produced unwanted stresses on the typical fixed fitting that is bolted to the mid-point of the gate because the ram does not follow a completely horizontal trajectory during its movement, leading to distortion of the fitting and the bolt through the gate.  Does anyone know where to obtain a more flexible fitting at a reasonable price perhaps using ball & socket or alternative connection between the two objects?  I've looked but solutions appear to be for robots!
There must be many driveways that are not horizontal and we cannot consider a sideways gate operator.
BillBo
  Ditec sliding gate opener Exit Stage Left 0 1,450 18-02-2026, 05:53 AM
Last Post: Exit Stage Left
  Gate sensors does not work when raining vanbinh 5 24,920 14-06-2024, 12:13 PM
  Could Someone Give me Seeking Advice on Gate Installation for Home Security? tysonzach 0 4,613 13-05-2024, 06:49 AM
Last Post: tysonzach
  nice gate openers John Thorpe 1 11,833 19-08-2022, 03:14 PM
  CB11 gate opener testing me!!!! lou trudge 0 9,346 22-12-2021, 10:40 AM
Last Post: lou trudge
  Gate Rail Sweeper/Brush Privateersman 0 10,870 10-02-2020, 03:50 PM
Last Post: Privateersman
  GIBIDI gate motor closing problem davidcunningham 0 12,193 26-04-2019, 08:20 PM
Last Post: davidcunningham
  Swing Gate arm not moving! a64664137 4 27,176 19-03-2019, 12:50 PM
  Help identifying electric gate fob Nick180582 5 31,735 22-10-2017, 01:22 PM
  Diatem Gate Keypad - removing cover hazel.luskin@gmail.com 0 10,023 20-05-2016, 11:28 AM
Last Post: hazel.luskin@gmail.com
