10-05-2026, 12:15 PM
(This post was last modified: 10-05-2026, 04:23 PM by McP_Farringdon.)
Hi, I have an old TOONA series 5 (TO5024) and the manual release no longer works on one ram.
I can open the release handle and it levers down the release pin but not far enough. I could see everything is at least moving inside when I opened the arm up - nothing is seized. The manual release doesn't work because the motor remains engaged. It appears the release pin (a little vertical rod which gets pushed down by the release handle) doesn't push the clutch away from the worm drive far enough. Looks like it needs ~2mm more vertical movement on the release pin. Is there an adjustment mechanism somewhere? There is also a spring inside the clutch (worm wheel assembly) although you can't actually see that - is that something that gets worn? It still feels springy. Any tips would be great.
I have now removed the release handle and also tried replacing the brass coloured release pin (you can see the domed tip of it in my pic attached) with a long bolt which I then pushed down hard as far as it would go. Even with presumably significantly more vertical movement on this release pin, the clutch is not releasing. Anyone else had this trouble and know a solution? I suspect it may be quite common. I'll open the whole thing up later this week and check the internal mechanism but I can drive the motor forwards and backwards with a 12V supply no problem.
