  • 16 Vote(s) - 3.5 Average
one gate partially opening - board failure ?
hoping someone has an idea about my issue ...
I have CAME ZM3E with 2 ATO swing gates.
All was working before the below, for at least a year.
The below detailed tests can be repeated on the other gate if I switch the power and Encoder plugs around ( ie gate 1 becomes gate 2 and vice versa ). ie seems not a gate motor issue.
I have tried manually closing the gates and turning off the pwoer for ~2 mins to see if a reset happens - didnt fix.
I did a 'reset' on the menu to see if that helped - nope.
all done with sensors turned off.
Any ideas ?
tests to try and bottom out.
(1) with gates fully open -> set encoder ... gate 1 closes  ~15 degress ; gate 2 closes fully then opens fully ; gate 1 opens the ~15 degress back to the original start position ( encoder error on screen for gate 1)
(2) gate 1 manually partially closed by ~45 degress .... same as above
(3) gate 2 open and gate 1 closed or partially open ... repeated press of open button on keyfob opens gate 1 by ~15 degress each time button pressed until fully open.
(4) turn gate 1 to manual ... whether encoder or manual press, can her gears whirrring for just what is probably 15 degress if engaged - ie no attempt to keep going.
(01-05-2026, 04:28 PM)kathome Wrote: Hi,
Any ideas ?
Thank you for your message.
Can you confirm on your control board where the motors are if there are two white cylinder units connected onto the motors phases, these are known as capacitors.
Firstly if you swap the capacitors over does the fault change to the other motor, if so then it is a replacement capacitor that must obtain.
If not, then I would swap the motors over in the control board and try run them again, if the other motor begins faulting then this indicates that there is something wrong with the board, potentially a setting or a calibration is needed.
However, if the fault stays with the same motor then I would say it could potentially be something to do with that motor in particular, perhaps cabling?
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 4 25,144 07-09-2026, 03:47 PM
Last Post: arlingtongate
  Gate mobile phone ‘relay’ jam_rs 3 7,409 06-09-2026, 10:16 AM
Last Post: DialOpenUK
  Came gate opener remotes Alexlambrook76 1 3,351 19-05-2026, 02:07 PM
  One side opens erratically - both gate stops sheared?? bomitie 0 2,614 18-04-2026, 03:18 PM
  Gate transmitters intermittently working Nice MC824H solihul 1 4,538 28-01-2026, 10:17 AM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 5,200 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 84,517 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 10,377 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 5,054 11-11-2025, 04:41 PM
  Circuit board disabled CB124 - 7 flashes Tussun 6 25,490 15-08-2025, 01:57 PM
