  • 22 Vote(s) - 2.73 Average
Came gate opener remotes
Just thought I would share this about NEW CAME REMOTES and COMPATABILITY. I bought 2 new TOP44RBNs from a French company that on the web stated that were a 'replacement' for the earlier TOPD4RDSs and was told they were totally compatible and the new could be connected by direct transfer from the old. After a lot of faffing about the 44s would not link and the lights didn' t do what they said they would do either on the web site or indeed on the instruction sent with the products. A very helpful Riley from Came UK advised that the two could not be synced and the 44s had to be connected direct to the mother board in the power unit. Ok  - easy to take off the front cover, then to work out which button to press as the instructions on line are misleading. It is in fact 'ent' on the right of the 'go right' button just below the little screen. You select 'user management' by clicking right then 'ent' then 'new user' ent which produces a code running accross the scree - let it get about 75% along and press the left hand top button on the new remote, DONT HOLD it. then 'esc' and you are good to go.... Smile Smile Smile
(02-04-2026, 05:50 PM)Alexlambrook76 Wrote: Just thought I would share this about NEW CAME REMOTES and COMPATABILITY. I bought 2 new TOP44RBNs from a French company that on the web stated that were a 'replacement' for the earlier TOPD4RDSs and was told they were totally compatible and the new could be connected by direct transfer from the old. After a lot of faffing about the 44s would not link and the lights didn' t do what they said they would do either on the web site or indeed on the instruction sent with the products. A very helpful Riley from Came UK advised that the two could not be synced and the 44s had to be connected direct to the mother board in the power unit. Ok  - easy to take off the front cover, then to work out which button to press as the instructions on line are misleading. It is in fact 'ent' on the right of the 'go right' button just below the little screen. You select 'user management' by clicking right then 'ent' then 'new user' ent which produces a code running accross the scree - let it get about 75% along and press the left hand top button on the new remote, DONT HOLD it. then 'esc' and you are good to go.... Smile Smile Smile
Brilliant, thank you for sharing this.
  I Need Advice on Choosing the Right Automatic Gate System. lizaclarraa 4 23,907 18 minutes ago
Last Post: arlingtongate
  Gate mobile phone ‘relay’ jam_rs 3 6,500 Yesterday, 10:16 AM
Last Post: DialOpenUK
  one gate partially opening - board failure ? kathome 1 2,184 19-05-2026, 02:06 PM
  One side opens erratically - both gate stops sheared?? bomitie 0 2,104 18-04-2026, 03:18 PM
  Gate transmitters intermittently working Nice MC824H solihul 1 3,956 28-01-2026, 10:17 AM
  SEAV LRX-2186: gate opens a bit then stops mehsom 2 4,840 09-01-2026, 10:38 AM
  Hikvision DS-KD8003-IME1 video intercom to Nice Robus 600 gate motor help j1000 31 82,239 09-01-2026, 10:03 AM
  Help me identify this mystery gate opener alpha 5 9,835 23-11-2025, 02:35 AM
Last Post: alpha2
  Auto Gate Help Fenderuk 1 4,729 11-11-2025, 04:41 PM
  Peculiar automatic gate behavior Gatefreak 1 8,040 09-05-2025, 12:36 PM
