  • 25 Vote(s) - 2.92 Average
Installing external antenna for BFT Deimos A600
Can anyone help me figure out how to route an external antenna cable out of the BFT Deimos A600 enclosure? It's a tight fit around the base so it's not obvious to me how you physically get an external antenna cable out of it. Many thanks in advance. I'm sure I'm missing something obvious.
To route an external antenna cable out of a BFT Deimos A600 enclosure, utilise the pre-existing cable entry points at the bottom of the unit, which are designed for power and accessory cables. Use a spare rubber grommet to seal the hole around the coax cable, preventing insects and moisture from entering.
Kind regards
Prem
(07-05-2026, 10:00 AM)Prem Wrote: Hi,
Thank you so much!! I didn’t know there were cable entry points on the bottom — really appreciate your advice! Wish they’d put this in the manual!
Brilliant, thank you for your feed back it is greatly appreciated.
Please let us know should you incur any further issues or have any queries, we will be happy to assist.
  Question BFT Deimos A400 Makaroni 2 7,158 07-05-2025, 05:58 AM
Last Post: OnionBobo
  Deimos ultra bt a400 Gate to stay open Sootylfc 0 4,052 04-11-2024, 05:59 PM
Last Post: Sootylfc
  Deimos ultra bt a400 gate - not working with fobs Sootylfc 2 7,529 15-10-2024, 10:37 AM
Last Post: Sootylfc
  bft deimos ultra bt600 error f1 pfloyd 4 13,089 04-10-2024, 03:36 PM
Last Post: pfloyd
  BFT Deimos BT A600 fault Error 10 Airbus330/300 5 18,661 06-03-2024, 11:59 AM
Last Post: GateOpe
  BFT deimos smoke from board stanli200188 1 5,542 05-03-2024, 04:17 PM
  BFT Deimos Ultra remote problems shaggy 1 16,189 01-05-2019, 09:43 PM
Last Post: ok.dude
  BFT Deimos Ultra BT A 600 + Tbox ok.dude 1 12,060 30-04-2019, 09:32 AM
Last Post: ok.dude
  BFT Deimos - How to fit a GSM Switch. MyGatesDontWorkSoGood 0 9,382 02-06-2018, 04:46 PM
Last Post: MyGatesDontWorkSoGood
  BFT Deimos A600 (HAMAL control board) troubleshooting EnricoTerni63 1 22,669 23-12-2017, 05:38 AM
Last Post: TAOZ
