  • 43 Vote(s) - 3.09 Average
CAME F7000 Gate Openers Issue
Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Thanks in advance,
Jack
Hi Jack,
Hi Jake,
Really appreciate your response. I don't have any photocells connected, in fact I have disconnected everything external including the antenna for the remote to check if there was a problem there. Despite everything being connected, it is still constantly flashing the red light like it is receiving a signal. When I do connect, even when I link in 7&2 directly, I don't get any relay click and nothing springs into action. I purchased another PCB just in case and swapped it over, but this one has the same issue and the red light remains constant.
Thanks,
Jack
Thanks,
Jack
Hi Jack,
Thanks in advance,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Hi Jake, apologies it took so long to reply.  The control board is the ZF1 and the red led flashing is in the bottom right of the board next to the antenna connection. Note that everything is unplugged and it is still flashing, even when I have changed the board.
Thanks,
Jack
Thanks in advance,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks for coming back to us on this, just wanted to try something if not tried already to ensure that there is no pre-existing faults on the control panel.
On the CAME ZF1, you have two sets of terminals which are safety inputs on the control board labelled as 2 and C1 and 1 and 2.
If you get some cable, strip either end off the cable and put a link wire between 2 and C1 and another link wire between 1 and 2.
Then try and short across terminals 2 and 7 and see if the gates operate.
Thanks in advance,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
[quote pid="18442" dateline="1762155607"]
[quote pid="18424" dateline="1757581471"]
[quote pid="18422" dateline="1756741845"]
Hi Jack,
[/quote]
[/quote]
[/quote]
Hi Ben,
Sorry this has taken so long to respond. I didn’t see a response had come through. I have done as you said and the gates work. They also work when I press the key fob with the rf module plugged in and the aerial.. When I don’t have the bridges in place the light continues to flash and nothing works. To confirm, there are no other accessories now plugged in and when I plug the keypad in it doesn’t work. I’m assuming that’s because the bridge is in place?
Thanks for getting me this far… the gates at least work on the fob which proves the motor and control panel are working!
Any ideas as to why it only works with those bridges would be helpful.
Thanks,
Jack
  Came za3 one gate not working from fob darrenp363 1 3,838 28-01-2026, 10:21 AM
  CAME ZF4 Controller Issue mduffy89 1 5,130 11-11-2025, 03:14 PM
  CAME sliding gate drops codes after power outage Catch 1 11,762 02-03-2023, 03:18 PM
  Link Came F7000 gate openers to Enterview 3 Intercom Jackolantern 2 19,216 23-04-2020, 07:11 PM
Last Post: Luke Scott
  CAME ZLJ24 panel - Open gate indicator-light Domcov 1 26,378 02-05-2018, 06:18 PM
  Came sliding gate sticking on opening Jellybean 0 16,074 02-07-2016, 06:53 PM
Last Post: Jellybean
  Came gate opening adjustments TobagoGate 0 36,726 20-12-2012, 02:40 PM
Last Post: TobagoGate
