  • 29 Vote(s) - 2.83 Average
Nice robus not closing
Any help would be great
I have a nice robus that won’t close
It seems like the photocells as it clicks when pressing remote and if I close gate manually it opens
 How do I disconnect photocells to test if it’s them ,
I believe I have to bridge some wires but not sure which ones
Cheers
Hi Dantay,
First of all, I would get this fault to happen again and following this, have a look at the BUS LED which is a diagnostic. You would need to count how many flashes there is before there is a pause, you can then refer to the diagnostic codes in the manual or you can let me know. If the LED is flashing once per second, this indicates no issue.
To test without photocells you would need to remove the cables going into CLOSE and put a link between those two terminals in CLOSE.
I hope this was useful.
Many Thanks
Aiden
  Robus RBS600 Help please! jasons6930 3 1,299 17-02-2026, 10:24 AM
  Nice Robus closing after photo Nexur 1 9,103 26-08-2025, 01:47 PM
  Nice LFAB occasionally failing open DaveHG 3 11,800 20-08-2025, 01:52 PM
  Nice gates don’t close after the ambient temp is high Howard 2 9,813 15-08-2025, 02:01 PM
  Nice Control unit passcode removal Andruelectricgates 1 5,413 17-06-2025, 11:25 AM
Last Post: HarrisonN
  NICE gates open slightly then stuck Overthefence 2 6,388 21-05-2025, 10:54 AM
  Nice Robus 250 HS Fuse Problem GLM 1 6,224 09-05-2025, 01:07 PM
  Looking for help with oldschool NICE gate motor gatekeeper 0 6,264 16-02-2025, 05:16 PM
  Diagnosing Nice SFAB2024 (ex XME2024) Motors devlinjayse 0 3,694 08-02-2025, 07:22 PM
Last Post: devlinjayse
  Nice RB600 - Automatic close fail and opening issues P100D 6 11,550 10-12-2024, 11:29 AM
