  • 4 Vote(s) - 2.75 Average
BFT photocell low power/no power
Hi, I have BFT Sub 24v motors which have worked more or less, for some years - a drunk driver hit my gate posts which have now been rebuilt. The board powers up and everything seems to work OK but the code "Photocl" shows constantly. I realise this is the board thinking the photcells are not clear but I cannot seem to get them working. No matter what cells I use, the maximum power I get on connection 1&2 on the photocells, or on port 50&51 on th Thalia board is less than 1v.
I am thinking I am simply not getting enough power from the board. Is there any other reason this wouldn't work? I am testing using a multimeter set to 20v dc testing and it reads 0.2. I also have a set of Nice motors elsewhere on the property and the same test process returns a reading of between 9-23v when the motors are active.
A simple keypad which also used to work doesn't power up from the same ports so I am really thinknig the board is not outputting enough to power devices.
All cables are tested and working - even when I try to wire it up locally I get nothing - no Photocell clicks like I used to.
Any advice welcome - I have had the gates out of action for a year whilst the insurers sorted things out and I waited for a stonemason to revuild the gate butts.
K
(20-07-2022, 01:27 PM)kmeand Wrote: Hi, I have BFT Sub 24v motors which have worked more or less, for some years - a drunk driver hit my gate posts which have now been rebuilt. The board powers up and everything seems to work OK but the code "Photocl" shows constantly. I realise this is the board thinking the photcells are not clear but I cannot seem to get them working. No matter what cells I use, the maximum power I get on connection 1&2 on the photocells, or on port 50&51 on th Thalia board is less than 1v.
K
Thanks for the message,
in this instance i would agree with you and say the output on the board is faulty as these panels do not have accessory fuses, in would personally try using a standalone PSU to overcome this issue.
our part code HDR15-24 or HDR-15-12
Hi K,
If you have tested the positive and negative on the board and you are not receiving sufficient power then unfortunately, the board will need replacing or you will require using a separate power supply to power both the photocells and keypad or any other added accessories.
regards
Mike
  BFT photocell query Adamit 1 401 11-04-2024, 08:02 AM
  Thalia - Photocell Close J to the D 1 754 19-01-2024, 09:54 AM
  Accessory Power Caesium 4 12,925 02-06-2020, 11:33 AM
Last Post: Smith1105
  ICARO + LEO B CBB : 12V power for keypad? tommysharp 5 22,555 17-02-2020, 02:24 PM
Last Post: Caesium
  Power surges markyjoe27 3 10,413 15-05-2019, 10:35 AM
