  • 13 Vote(s) - 2.92 Average
Faac 740
Hi there guys first time poster stumbled across your forum while troubleshooting.
Would appreciate some help if there's any going.
Installed above opener today all went well but having a bit of trouble.
Gate will not open or close.
On the logic side when gate is open I get correct PI(03),when gate is closed correct PI (00) however if I attempt to open gate logic changes to stopped (02) until it's pushed all way open at which point PI changes to open (03) then when I got to close,it does not change over to now closing(06) rather remains in open logic until it changes to close.
I have one set of closing photocells, open fsw has been shorted along with the stop and edge.
What's throwing me is the stop command where is it being generated from
Anywhone any help on this would be much appreciated
All sorted
Hi Mozil
It looks like I have the same problem that you had.
How did you manage to resolve?
(07-09-2019, 08:33 PM)Mozil Wrote: Hi there guys first time poster stumbled across your forum while troubleshooting.
Hi,  I am having the exact same issue, any chance you could post how you fixed it, thanks.
  Faac 452 pcb board benner91 2 1,585 09-02-2024, 06:13 PM
  Faac photocell stopped working Zeb Gulickx 2 843 28-01-2024, 12:56 PM
Last Post: Zeb Gulickx
  FAAC E124 fault 05 allan@amtas.com.au 0 700 14-10-2023, 12:37 PM
Last Post: allan@amtas.com.au
  FAAC 740 Sliding gate Just closes or Stops Paul L 1 3,762 03-07-2023, 08:54 AM
  7pcb452/455 FAAC Alpin 0 1,190 23-06-2023, 03:19 PM
Last Post: Alpin
  FAAC Photocells mmc1977 3 2,277 02-05-2023, 12:37 PM
  water damage to FAAC photocell Rajab 4 3,533 18-07-2022, 09:00 AM
  455d FAAC FUSE IN CONTROL PANEL wildfig 0 2,068 04-10-2021, 02:34 PM
Last Post: wildfig
  FAAC foundation plate mun31 1 4,980 30-06-2021, 09:33 AM
  Older FAAC gate no power to circuit board tfb208 0 7,281 19-11-2020, 06:10 PM
Last Post: tfb208
