  • 118 Vote(s) - 2.7 Average
HELP
regards
Best Regards
Tom
HELP
  Came ZA3 gates stuck open Ivorwindybottom 0 260 18-02-2024, 06:29 PM
Last Post: Ivorwindybottom
  Electric Gates with AllMatic BIOS2 Unit antsnaith 3 1,207 31-01-2024, 08:22 AM
Last Post: patronsecurity
  Came gates za3p Webby 4 8,822 07-01-2024, 07:11 PM
Last Post: Simon NW
  Disable Open hold On NICE NC824 paul@blxnetworks.co.uk 4 1,675 02-10-2023, 09:20 AM
  Nice Gates not closing StuL 1 1,351 24-08-2023, 01:34 PM
  Gates Opening After Closing tht7 2 9,459 30-07-2023, 12:30 PM
Last Post: lcpbarbosa
  Holding the Gate Open mgb 1 3,472 11-07-2023, 01:35 PM
  Came gates stuck open. Ring8180 7 16,653 23-02-2023, 01:08 PM
  Proteco controller & ACT5e keypad - keeps tripping fclauson 4 3,849 26-08-2022, 03:42 PM
  Proteco Q60 - FH error then close after opening Needlerp 1 2,312 24-06-2022, 09:54 AM
