  • 15 Vote(s) - 2.67 Average
Gate wont close issue
Hi all, I have had a good read of a lot of threads on here and can’t see the to find my exact issue.
I have a sliding electric gate (BFT Deimos Ultra BT A 600) and after opening it this morning it now wont close.
The LCD on the PCB displays Phcl  which from looking at manual is PHOT CL closing photocell input activated.
It is raining outside and I’m wondering if this has caused the issue with ingress causing a problem with one of the photocells.
I am a bit new to the diagnostics of these issues so any help would be appreciated.
There are two sensors on the sliding gate which align when open/close with a sensor on the ground unit.
There are two static photocell sensors on either wall of the gate entry which I’m assuming is the safety beam aspect.
Is the Phcl error to do with the ones on the wall?
Hope you can help.
Turns out I solved this myself in the end.
It was the battery in the photocell TX/RX module on the wall. Just needed a new 3V battery (size C2).
Figured I’d leave the post here just incase it helps anyone else with similar situation.
Apologies if basic user error for most people.
  Bft gate problem djkokalis 1 903 14-02-2024, 12:39 PM
  BFT Sliding Gate randomly opening and closing AdrianMate 1 608 14-02-2024, 12:18 PM
  Ecosol/Kustos doesn't open and close fully? supremee 3 2,063 09-02-2024, 03:12 PM
Last Post: EdwardBab
  Thalia - Photocell Close J to the D 1 511 19-01-2024, 09:54 AM
  BFT Rigel 4 - single Gate Not Closing Tsnash 1 865 04-01-2024, 10:21 AM
  BFT sliding gate intermittent operation vozm100 5 1,812 02-10-2023, 09:08 AM
  Set remote to “only open” gate mark123499 4 3,508 30-05-2023, 01:57 PM
Last Post: mark123499
  Parallel (or not) gate motors Ian Evans 1 2,404 16-05-2022, 11:44 AM
  RCD trip on close LUX 2B DP86 3 6,582 14-04-2022, 08:55 AM
  BFT Thalia GSM gate opener SunnyB1 1 2,959 07-03-2022, 10:58 AM
