I have LYN300 Gates Openers and Liftmaster CB24 Control unit and up and until now been extremely happy. However, over the weekend they have just stopped responding to the remotes - All 3. I have tried the following, removed / replaced all batteries (on remotes) along with trying to re-program the key fobs with the control unit. The control unit appears to be fine (power etc) however will not pick up any of the key fobs now.
Any advise would be greatly appreciated. Thank you
Hi Tim
When you press your fobs do you hear the relays clicking on the control board ?
have you checked your photocells ?
Sparky Wrote:Hi Tim
Sparky Wrote:Hi Tim
Hi Sparky, thanks for your response. I can confirm the relays are not clicking (am familiar with what you mean). Not sure about the photocells?
Thanks,
Tim
Delighted to say CB24 Control Panel and Automatic Gates are now responding and fixed.
Big "Thank you" to Mark @ Easygates for talking me through a series of checks : checking fixing for aerial and reseting panel by removing all power Inc Back Up Batteries - After which the unit jumped back into life.
Well done Easygates.
Tim
Hi Everyone,
I just gone through the entire post thanks for your suggestion i also facing the same problem as CB24 Stopped is not responding,well due some of the suggestion in the forum i had solved my problem
