Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
I have F7000 openers. I started to get an intermittent issue whereby the gates would open but then not close. Only a few times per week. Then it has got to the point where the gates don't respond at all. From the beginning I noticed that the red LED was flashing constantly.
To try and fault-find, rightly or wrongly I stripped back all the connections from my sensors, external accessories etc to narrow down where the issue was coming from. It seems that the red LED indicator on the board is constantly flashing which suggests that it receiving a signal from somewhere. Therefore every time I pressed the button on the keyfob or keypad it couldn't receive the signal as it was 'engaged'. However, with everything disconnected, it does the same - the LED is flashing. Very occasionally I could press the fob and get them to open, but never will they close via the same method.
In my wisdom, I decided that maybe there was a board issue and maybe even a relay had gone or was getting stuck. I bought a new board and swapped them over. Same issue. Even with everything disconnected. It can't be the capacitor as I only replaced a few years ago and it is both gate openers that don't move.
It's worth noting that there has been creepy crawlies inside the box and so they may have shorted something or done some damage somewhere.
I'm now out of ideas and would appreciate any help and support you are able to offer as it is driving me mad!
Thanks in advance,
Jack
(17-07-2025, 01:54 PM)Jackolantern Wrote: [ -> ]Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Hi Jack,
From your description of the issue there could be a problem with the photocells where they think there is an obstruction or alternatively the gates could be receiving a constant open command from something like an intercom or keypad, what accessories do you have connected to the board?
Hi Jake,
Really appreciate your response. I don't have any photocells connected, in fact I have disconnected everything external including the antenna for the remote to check if there was a problem there. Despite everything being connected, it is still constantly flashing the red light like it is receiving a signal. When I do connect, even when I link in 7&2 directly, I don't get any relay click and nothing springs into action. I purchased another PCB just in case and swapped it over, but this one has the same issue and the red light remains constant.
What can I be missing? What can I test? Any help greatly appreciated as this is driving me nuts!
Thanks,
Jack
(11-08-2025, 04:56 PM)Jackolantern Wrote: [ -> ]Hi Jake,
Thanks,
Jack
Hi Jack,
What control board is it that you are using? Also could you just confirm which red light it it is that is staying on constant?
(11-08-2025, 04:20 PM)Jakedugmore Wrote: [ -> ] (17-07-2025, 01:54 PM)Jackolantern Wrote: [ -> ]Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Hi Jack,
(12-08-2025, 04:14 PM)Jakedugmore Wrote: [ -> ] (11-08-2025, 04:56 PM)Jackolantern Wrote: [ -> ]Hi Jake,
Thanks,
Jack
Hi Jack,
Hi Jake, apologies it took so long to reply. The control board is the ZF1 and the red led flashing is in the bottom right of the board next to the antenna connection. Note that everything is unplugged and it is still flashing, even when I have changed the board.
Thanks,
Jack
(01-09-2025, 04:50 PM)Jackolantern Wrote: [ -> ] (11-08-2025, 04:20 PM)Jakedugmore Wrote: [ -> ] (17-07-2025, 01:54 PM)Jackolantern Wrote: [ -> ]Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks for coming back to us on this, just wanted to try something if not tried already to ensure that there is no pre-existing faults on the control panel.
On the CAME ZF1, you have two sets of terminals which are safety inputs on the control board labelled as 2 and C1 and 1 and 2.
If you get some cable, strip either end off the cable and put a link wire between 2 and C1 and another link wire between 1 and 2.
Then try and short across terminals 2 and 7 and see if the gates operate.
(11-09-2025, 10:04 AM)benbrooks Wrote: [ -> ] (01-09-2025, 04:50 PM)Jackolantern Wrote: [ -> ] (11-08-2025, 04:20 PM)Jakedugmore Wrote: [ -> ] (17-07-2025, 01:54 PM)Jackolantern Wrote: [ -> ]Hi All, this forum is always so helpful and hoping for a fix once again so, fingers crossed.
Thanks in advance,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
Thanks,
Jack
Hi Jack,
[quote pid="18442" dateline="1762155607"]
[quote pid="18424" dateline="1757581471"]
[quote pid="18422" dateline="1756741845"]
Hi Jack,
[/quote]
[/quote]
[/quote]
Hi Ben,
Sorry this has taken so long to respond. I didn’t see a response had come through. I have done as you said and the gates work. They also work when I press the key fob with the rf module plugged in and the aerial.. When I don’t have the bridges in place the light continues to flash and nothing works. To confirm, there are no other accessories now plugged in and when I plug the keypad in it doesn’t work. I’m assuming that’s because the bridge is in place?
Thanks for getting me this far… the gates at least work on the fob which proves the motor and control panel are working!
Any ideas as to why it only works with those bridges would be helpful.
Thanks,
Jack
