Hi my swing gates won't operate and are stuck at 50% open , I learned the CB11 control board and removed the jumper and pressed the L1 button and the photo cells are just flashing and not a sound or movement from the motors on the gates , can you help and point me in the correct direction to fix this issue thanks Joe
(25-03-2024, 12:41 AM)jctrotting Wrote: [ -> ]Hi my swing gates won't operate and are stuck at 50% open , I learned the CB11 control board and removed the jumper and pressed the L1 button and the photo cells are just flashing and not a sound or movement from the motors on the gates , can you help and point me in the correct direction to fix this issue thanks Joe
Thanks for the email.
can you confirm the link is still in the stop terminal and the resistor in the edge terminal.
