Full Version: BFT Sliding Gate randomly opening and closing
Hello All,
I have a BFT Deimos sliding gate that when fully closed, will randomly start opening and then stop half way, start closing again, stop before closing, and start opening again.
The gate has worked perfectly fine for a decade, and suddenly started playing up.
I have replaced the photocells, both entry and exit pin pads, gate motor and board. I have also tried using the autoset function so the gate can relearn itself, however the problem still happens right away afterwards.
Open to all suggestions, I'm at a loss as to why this would suddenly start happening, Please help!
Hi Adrian,
Have you disconnected all accessories from the board such as push button, intercom, keypads?
I would disconnect all accessories from the board just in case one of these are causing the issue.
Mike
