Full Version: NICE MC800 Factory Reset
Anyone know is there a factory reset ability on the MC800 ?
The manual has instructions to reset memory settings to default by pressing the start and stop buttons simultaneously but this is not doing anything.
When I power up my MC800 I get the BlueBus flashing green but every 4 seconds approximately it also flashes red. Also L1 to L8 are all flashing red.
The motor leds M1 and M2 are both flashing green.
I disconnected the two grey block connectors leaving just the motors connected to the unit but that makes no difference, still all the flashing leds!
Anyone seen similar behavior?
Cheers
bg
A BLUEBUS flashing light 4X indicates, there is an intervention of the STOP input. Do you have anything wired into the STOP input like safety edges?
To do a complete reset you must press and hold down OPEN and CLOSE simultaneously for around 5-10 seconds. However, this will not rectify your issue, if it is a safety issue.
Easygates Ltd
When I disconnect everything and just have the motors connected to the unit I still have the same issue!
Brendan
(09-10-2023, 11:00 AM)bg148 Wrote: [ -> ]Hi,
Brendan
Hi Brendan,
now you only have the motors connected you can perform a factory reset by holding down Open & Close simultaneously for around 5/10 seconds.
 everything will flash and go out when the reset is complete.
then do a Blue Bus search and a position search with just the Motors connected.
Kind Regards
Matt
Unfortunately no joy, everything disconnected, and no reaction from the unit on the reset.
Brendan
(10-10-2023, 09:00 PM)bg148 Wrote: [ -> ]Unfortunately no joy, everything disconnected, and no reaction from the unit on the reset.
Brendan
Hi Brendan,
is there any chance you could give me a call on 01384569942 opt 2 please?
