Full Version: Thalia P - Wireless control board module
HI,
Does anybody know if it is possible to replace just the wireless remote module inside a Thalia P control board?
All my remotes have simply stopped working, but everything else functions including the photocells and keypad entry. I have tried reprogramming the remotes and gone through the process as assigning the open button. The control panel seems to detect the fob, when both buttons are pressed, but when you assign the desired button to activate opening the display shows KO rather than OK.
So im wondering if its a problem with the remote module within the control panel itself and if its possible to replace just that particular element?
(01-03-2023, 11:04 AM)mathewnorris22 Wrote: [ -> ]HI,
The receiver on the Thalia P is integrated into the control board.
If that has failed. You may need to use an external receiver. In this case it would be the clonix 2e.
This would then get wired as followed.
Terminal 50 = - negative 24v/ground
Terminal 51 = +positive 24v
Terminal 60 = Common ©
Terminal 61 = Normally open (NO)
