I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
(29-09-2022, 05:05 PM)Noghar Wrote: [ -> ]I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
Good Afternoon,
Thank you for your enquiry.
The inti remotes are essentially a smaller version of the ERA ONE remotes. They will be compatible as they are the same coding and frequency.
Kindest Regards,
(30-09-2022, 03:04 PM)SamA Wrote: [ -> ] (29-09-2022, 05:05 PM)Noghar Wrote: [ -> ]I am in the process of having new gates fitted with a Nice opening mechanism. The installers have offered me ERA ONE remotes, black and white, but on the EasyGates site I found Era INTI remotes that look similar but are more colourful. My question is, are the INTI remotes/transmitters compatible with an ERA ONE receiver? They seem to use the same frequency but I have not seen the INTI transmitters described as a viable replacement for Era Ones.
Thanks in advance!
Good Afternoon,
Kindest Regards,
Thanks, but I received exactly the opposite advice from tech support at Easy Gates, who said the two transmitters were not compatible, and I would needĀ an additional receiver. So now I don't know what to think. I may buy an inti and try it for myself.
" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
(30-09-2022, 07:46 PM)Noghar Wrote: [ -> ]" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
Hope this helps.
(06-10-2022, 10:29 AM)SamA Wrote: [ -> ] (30-09-2022, 07:46 PM)Noghar Wrote: [ -> ]" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
Hope this helps.
Thanks for your help.
(07-10-2022, 02:20 PM)Noghar Wrote: [ -> ] (06-10-2022, 10:29 AM)SamA Wrote: [ -> ] (30-09-2022, 07:46 PM)Noghar Wrote: [ -> ]" The Inti remote controls cannot work alongside the standard Era One coding fobs I am afraid, the reason for this is that one style of fob uses the O-Code programming and the other Flo coding and therefore cannot work synergistically.
Hope this helps.
Thank you for your response,
We are glad that we can be of assistance to you.
Many thanksĀ
