(10-10-2022, 09:58 AM)j1000 Wrote: [ -> ]Hi Joe,
Appreciate any advice.
Thanks for the message,
Could you please give me a call on the number 01384569942 opt 2.
Hi J1000, Joe,
I have the very same issue. Can i ask how you fixed it ?
Thank you!
BR,
Kamil
(16-01-2023, 06:25 PM)Kamil Wrote: [ -> ]Hi J1000, Joe,
Thank you!
BR,
Kamil
Hi Kamil,
Unfortunately we tried several things but nothing worked.
I will reply to your message.
The only thing i can think is that you have set the SBS to pedestrian opening instead of condiminum 1 (L4).
Hi Sam,
Thanks for your reply.
Do you know how I can change the sbs to allow for full opening?
Cheers again.
(03-02-2023, 12:09 PM)j1000 Wrote: [ -> ]Hi Sam,
Cheers again.
As standard, the SBS functions are full opening. Other than "L6" - Step-by-Step 2 (less than 2” causes partial opening)
Thanks Sam.
Will give that a go.
(03-02-2023, 12:17 PM)j1000 Wrote: [ -> ]Thanks Sam.
Great, any issues let us know.
The SBS input should allow for a closing manoeuvre when impulsed in the open position, if the gate is moving a few feet then stopping can you confirm how many times the BUS led is flashing?
