Full Version: CAM ZA3 Single control board
@page { size: 21cm 29.7cm; margin: 2cm } p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
Hello help please
 I have a CAM ZA3 (222297) Single control board (about 10 years old) for my double gates the yellow flashing Cycle light has stopped working and trips the fuse, I have removed the live wire from the control board that stopped the fuse from tripping out, I next bypassed the control board and tested the Cycle flashing light with a 240v cable and works fine . advice please
With thanks Rookie
Rookie
(26-03-2022, 10:10 PM)Rookie Wrote: [ -> ]@page { size: 21cm 29.7cm; margin: 2cm } p { line-height: 115%; margin-bottom: 0.25cm; background: transparent }
Hello help please
With thanks Rookie
Rookie
Hi Rookie,
thanks for the message,
this to me sounds like a possible cabling short and is unlikely to be the actual control panel, have you proved the cabling to the flashing light for shorts between the conductor at all, i feel this is the most plausible explanation as to why this is happening.
Kind Regards.
Joe.
