hello i have a BFT Lux FC and just replaced one of the ram arms (hydronic arms) so everything was already in place i fitted it and its all working fine but when opening as it should then slows down and stops before reaching its stopper on the floor ??
any suggestions when i put it in manual mode it opens all the way and is smooth
(04-02-2022, 04:47 PM)jc.34@outlook.com Wrote: [ -> ]hello i have a BFT Lux FC and just replaced one of the ram arms (hydronic arms) so everything was already in place i fitted it and its all working fine but when opening as it should then slows down and stops before reaching its stopper on the floor ??
Hope you are well. The Hydraulic arms are filled with hydraulic fluid, if the arm is not reaching the full close position, you will need to bleed the arm. Bleeding the fluid will allow a greater open/close distance for the Ram. You should see a bleed screw on your ram arm, only turn this slightly as you do not want to lose excess fluid.
Kind regards
-Jamie
